- 2,799
- 73
- 48
- Mesquite, NV
So I have the PTO installed and working as it should (thanks to the advice from Phil). I have the brand new shaft ready to install so I can FINALLY try this thing out, but.....
When I installed the winch a couple years ago I tried to service the winch with fresh gear oil. All the plugs required heat to get out and the only fluid that came out was some milky water. I flushed it with some trans fluid and a spring from the passenger side seal popped out the drain. I tried to let the trans fluid sit in the winch overnight but it wouldn't hold. Of course it won't hold gear oil either.
Should I pull the winch before installing the shaft and swap the seal? Can I pour gear oil that's gonna leak out and at least test the winch to see if it works? Rumor is it used to belong to WM years ago so it's probably first rate. Should I get some Cornhead grease and dump it in?
All I want to do now is test the winch and if it works ok, install the cable and chain.
I would appreciate a little advice. I do have a full set of seals, but **** that seems like a ton of work. Thanks.
