Smokingman
- 1
- 8
- Two Harbors MN
First I have done the starter relay mod, installed a new GPR109,put in new 31 series batteries(with new cables),cleaned all grounds,cleaned fuse box,new drivers side alt(passenger is charging fine) and replaced all fuses with new.The truck runs and drives well.
Now for the problems.
1.When starting the glow plug relay takes roughly 1.5-2 minutes to click,once it clicks the wait light goes out in 4-6 seconds.
2.The alternators are putting out amps,but the batteries are not charging(12.2 volts on the front battery when running 24.7 on the rear).
3.No lights.No dash,headlights,brake,or turn signals.
I need to add that the headlights will come on by turning on the black out light switch(service light) and the horn blows non stop(when the black out light is turned on).I think the horn problem is in the steering column and will take a look at that Monday.
