- 18,501
- 5,639
Nice thoughtshere is an idea for the gap between the cab and the camper you could mount 2 spares on something similar to the 5 ton rack.
You would still keep the storage below that rack. you then could ditch the spare tire carrier and mount another fuel tank there giving 100 gallons of fuel. and you could even keep the bed tank (I dont know how big that is.)
I think 2 spares there would fill that gap nicley and still have some storage. and if you blow a set of duals while the zombies are out you don't need a tire shop untill you blow the third tire.
Although, in regard to the SPARES.... Under the loads carried on this particular rig, there are already FOUR spares on the ground as well. Each of the rear duals could be stripped down to singles and still have mobility. I would dedicate that space to something that would carry additional provisions or other necessary equipment/supplies. IMHO.
