- 18,526
- 5,764
Congrats on the win.I have made a decision to use the M720!
Got one that looked like it has never been used since the shipping box which contains hoses etc is still strapped to it. When I inspected there was some easily repaired damage on the lunette stop and a flat tire. Most in the lot did not sell so it was way cheap.
I almost wish I had bid on two just in case I need an extra part but I didn't want to make two 300 mile+ trips for pickup. Shipping for two would have been about $400, still cheaper than I anticipated.
The dolly set tow speed for the M832 is listed at 30mph max when not carrying a shelter. No limit is shown for the M720 but I expect there may be similar issues because of the short wheel base or because of the light weight.
Anybody got ideas on how to increase safe speed? Maybe reduce tire pressure down to about 12lbs? I am considering adding a couple of struts to lock the steering and lift the front wheels off the ground so the dolly set will pull like a two wheel. I estimate 700 lbs tongue weight when set up as a two wheel. I have a weight distribution hitch I can use to improve handling of the towing vehicle.
I am towing it with a one ton 4x4 Ford van and will choose a route off the freeway. I will be inspecting and greasing the wheel bearings.
Now to wait for EUC. My first EUC took more than 60 working days. Hopefully they know me better now.
Keep up posted on your recovery and build please.
