395's front only
jasonjc
289
Gravette Ar.
I run 12.50R20 XL's on the front of 2 of my trucks. The seem to work real good and they trun better and handle better. The rears are still 9.00-20NDT's. The 12.50's and 9.00's are just about the same size. Like a new 9.00 vs an old 9.00. They look good too[thumbzup]
4,813
395's are way taller than 9.00's, like 6" taller. About 3" taller than a 11.00 as well.
Danger Ranger
23
Roland, IA
SETOYOTA
450
georgia
you should not run different diameter tires on the same truck. Your asking for trouble if you do.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
What thought?. Are we supposed to think before we post?.
I was wondering if anyone has super singled the front only before and I see that someone prior to me has thought of this. Sure makes 'em look better.
No, not really.
They used a tire that was the same height as their other tires. You are asking about different size tires.
205
Chicago, Illinois
I have thought about the possibility of putting a wider tire on the front. I like the look of the duals in the rear but would like a more aggressive/wider tire in the front. Sort of the look some of the concrete trucks have. I do understand that the tire diameters have to be the same in order for there not to be any problems if the front axel is engaged. Possibly using a re-centered HEMMTT rim???? But then what (if any) tires would be the same diameter/height as 9x20?
jasonjc
289
Gravette Ar.
See post #2:grd:
SETOYOTA
450
georgia
I believe you still will experience wind up even without engaging the front axle.
