DIESELGREEN
- 1
- 0
- Woodstock, GA
Ok, checked all the basics and researched back thru threads pertaining to gen 1 problems, but here goes... As of late, over the last month or so, I've been noticing my lights getting dimmer at night, and also my volt gauge is reading on the "high" side of the yellow area, used to be right in the middle of the green. finally, while I was doing other repairs today, she wouldn't start. once running again, tested both batteries, 12.40v rear and 11.5x front. gen 2, reads 26.xx volts and gen 1 (driver's side, hope I have the numbers right) is putting out about 11.5v. (close to reading of front battery. here's the other thing.. My gen 1 light has not been coming on. both are supposed to cycle/illuminate at key-on and startup, right? I replaced the bulb in gen1 spot and cleaned the contacts, no dice. I believe my #1 alternator has failed. will this make the gen1 light not work??? thanks in advance. P.S. batteries are both only 3 months old.
