Has anyone mounted a rear winch on a bobbed duece the same as its mounted on the front?The duece has a straight frame so it looks to me like you could use the upper & lower winch mounts and brackets on the rear the same as the front.It looks like the rear transfer pto would mount in a straight line if you flipped the frame cross members for clearence so the cut out is upward to clear the winch driveshaft. The garwood winch can be taken apart and the worm gear flipped for either side operation,Just wondering,it would be so nice to have the winch at the rear of the bed!
