M101 vs M105 Trailer
renovate7
Florida
Can a deuce tow a M101 trailer or is the tongue to low? Do I need to stick with a M105 if I want to tow? Also, do the 101's have any kind of brakes? The photos I've seen don't show and air hose/brake line like the M105's. Thanks for any input.
WillWagner
2,758
Monrovia, Ca.
The lunette is a tad low for towing with a deuce, but I have seen it done. Very hard to see while backing. No brakes unless it has been upgraded to surge brakes.
KsM715
142
St George Ks
If you already have a deuce to tow with then go for the 105. It might be a tad bigger but its way cheaper and it was designed to be towed behind the deuce.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
On the other hand, if you can only have one trailer and you want to tow it with both, the 101.will work. I have towed the A1, A2 and A3 versions with my deuces with no ill effect.
hdmax
new Lexington, Ohio
Get with Kipman; He towed an 101 with surge brakes to Haspin, so he has first hand experience!
Barrman
1,782
Giddings, Texas
Kwai and I towed a M101 behind a M109 600 miles one day a few years ago. They follow great. You can't tell it is there unless the early morning or early evening shadows are just right though.
