85M1009_89K5
- 0
- 0
- California/other
I just purchased an 85 m1009 about two weeks ago. I changed all the fluids, rotella oil, dex/merc trans fluid, dot5 brake etc. etc.
About a day later the starter went out, having spent all my money on buying, tagging, and doing regular maint. on the truck, i had to wait 5 days until the next payday. Got the new starter in, had a little trouble getting it started, but once it did start, it began knocking extremely loud. This happen about a week ago, I search online everywhere including here and diesel place to find out as much as I could about it. I removed each injector line to make sure it wasn't a stuck injector, with no luck. I had a mechanic friend of mine look at it, and he said it was most likely a thrown rod.
I'm in the army, and I will be PCSing (moving) in the next two months. I'm located in Huntsville Alabama, and i'm kinda in a bind. I would like to either get a running m1008 and swap that motor (and axles) in, or a 93 and older 6.5 engine. Any information leading to a good motor or any other help would be greatly appreciated.
