kennys@wi.rr.com
- 23
- 38
- Waukesha, WI
I too have the screws. What I did was to clean it all real good to start, then spray them with a good penitrating oil, leave sit over night while you pray. Then try. Also make sure you are using the correct size screw driver bit, so many people think they are one size fits all. If all else fails try an impact screw driver. I used one on my door hinges and it worked great. That is the kind you hit with a hammer and it backs the screw out. Best of luck.
