Needs some tips on fixing this dent
zout
154
Columbus Georgia
All in all - I would say "say la vieve" to that tank, seeing you have all the stuff to bolt back on er and just get another shell instead of screwng with that tank shell. I am sure you can locate one - find one to be less than what you would have screwing with this one.
This is not a negative post - it is a mattter of what will get you up and running with the least amount of time - effort and components.
A
A/C Cages
Guest
I simply used a mini air ram sitting on a chunk of wood for a base, Neighbors long skinny arms to reach in the tank. place it on the dented area..... little air, pop,,, very close to smooth finish. Biggest thing was the neighbors really freaky long skinny arms. She agreed to do it since she was the one who backed into the tank in the first place.
Gunfreak25
620
Yuma, AZ
Shoot, the truck is a work in progress. Still have to rebuild the engine, tranny, etc.
I went ahead and tack welded a plate to the dent earlier around noon. Ran out of wire, picked up some more and put a few more tacks on. I put the tank under the right side of the cargo bed (coincidentally both my wheels are off right now) and connected a hand winch to the steel plate. I filled the tank full of 56 gal of water to weigh it down, figure 450-500lbs total? It worked great! I pulled out over half the dent as well as the crease line at the top. I have to cut the plate off and do a little repositioning and a little more pulling and it will be done. I'll get pictures before I put any bondo on it so you guys can see how well it came out. Surprised that my spot welds held up so well too, the water filled tank made a superb heat sink.
Can't thank you enough, AMX. My first dent pull. :D
A
A/C Cages
Guest
Fuel of many types eat thru that bad word you said,,(Bondo)
Try AllMetal or the better one is LabMetal... They are kinda like JB Weld but much stronger and wont deteriorate once in contact with fuels.
Never Bondo
AMX
Walland tn.
Never Bondo
Properly prepared substate with a quality primer/sealer will allieviate any fuel problems. I have used many types of fillers including lab metal, most are still polyester based.
Gunfreak25
620
Yuma, AZ
I figure the bondo will be far enough back on the tank and once it's properly primed and sealed up with a couple coats of 24087 then any small fuel spill would be harmless.
