What have you done to your CUCV today/lately? - Part 1
rjinga
Monroe, GA
I made a frame to put my topper on. It is 2' high, 3' wide, and 4' deep. The white part is 3/4" schedule 40 PVC pipe; the dark part is 3/4" metal pipe. I was originally going to use 2" PVC, but my local Home Depot didn't have 2" corner fittings. Also, the friendly associate who helped me told me that the frame could hold the weight if I used metal in the vertical braces. I'll find out tomorrow and report back.
Hightechken
NE Wisconsin
Finally started to go through all the tools for the trucks, And put them away in proper places. Bigger job than I thought!
Also shop vac cleaned out all the toolbox compartments of both trucks.
Those compartments hold lots of stuff! Going to order another Victor torch knock off for the second truck so they will both be set up pretty much the same.
rjinga
Monroe, GA
I made a frame to put my topper on.... [T]he friendly associate who helped me told me that the frame could hold the weight if I used metal in the vertical braces. I'll find out tomorrow and report back.
The cap is on the frame and it's holding it up. I realized yesterday, right after I built it, that I need diagonal bracing too. Back to Home Depot I guess.
wrex
9
Laveen, Az
Drove it from San Francisco to Kansas City last week, then on to Lexington, Ky. Thurs, back to KC then on to SF again on Saturday. Will be about 4800 miles total, after all done.
Nico
15
Germany, Hamburg
Stock M1008 rims I have M1008 axles
I install m1008 tailgate on my M1009 and working on the fastback top now and I got a cab curtain for the summer to keep the rain out (still need snaps to install it).
hi allen!
how does the 1008 tailgate fit? a lot to change?
i just bought a soft top and wonder if i could do the same without a big fuss.
rjinga
Monroe, GA
Well, on further review, as my youngest son used to say: "I've changeded my mind." There isn't as much side-to-side flex as I thought there'd be after all. I'll keep a close eye on it during our next windy day, and see what happens.
AllenEM
Allen, Oklahoma
hi allen!
All you need is the hardware off the M1008 and remove the M1009 hardware bolts right up the bolt hole are already there.
jholler
Jonesboro, AR
If I build one of those I can have my sawhorses back...hmm!
rjinga
Monroe, GA
We had a pretty good thunderstorm last night with a strong wind, and the frame withstood it.
Oldsouthernboy
Jacksonville, al
I started on reinstalling my troop seats for the grand kids to ride in the truck back. I found that I did not have enough pins to go in the seats. A trip to tractor supply and the pin bin to find a replacement pins and cotter pins. Then the wife kindly told me that a state law does not allow any one under 15 to ride in the back of a pick up unless using a restaint system. dam now I have to find and install a whole wad of seat belts to take them fishing in the 1028. So much for a quick trip to the river bank.
jholler
Jonesboro, AR
I started on reinstalling my troop seats for the grand kids to ride in the truck back. I found that I did not have enough pins to go in the seats. A trip to tractor supply and the pin bin to find a replacement pins and cotter pins. Then the wife kindly told me that a state law does not allow any one under 15 to ride in the back of a pick up unless using a restaint system. dam now I have to find and install a whole wad of seat belts to take them fishing in the 1028. So much for a quick trip to the river bank.​
In the Guard, a "troop strap" across the tailgate area qualifies as a restraint...maybe that would get you grandfathered in same as if the vehicle isn't built with seatbelts? It IS the originally designed safety equipment.
