Hyd.Head Replacement
Josh
12
Portland, Oregon
Im going to swap out the HH on my truck to due to massive leaks at the injection lines, On my 2nd set of lines, so I've concluded its gota be the HH. Ive read about a dozent threads on how to swap it out, but I didnt see one mention seals or gaskets, Is there any seals or gaskets I need to replace?
Thanks.
m-35tom
222
eldersburg maryland
there are 2 'o' rings that you must replace. they should come with a new head. be very careful not to overtighten the fuel lines. i would have to look up the torque but i would guess maybe 20 ft lbs. too much can cause damage.
tom
doghead
4 Star General /Moderator
1,179
From the TM, for the fuel lines at the HH.
Tighten nuts (15) 23-25 lb-ft (31-34 N.m) and lower dust caps (16) over nuts (15).
davey8943
Columbus IN
Josh,
I bought mine from McMaster Carr.
Let me find the McMasterr number and Ill post it up.
Larger size: Viton 9464K239
"230"
2 3/4 OD
2 1/2 ID
1/8 Thick
Smaller size: Viton 9464K98
"227"
2 3/8 OD
2 1/8 ID
1/8 Thick
In fact, I had to buy about 10 of each (minimum order quantity). If you want one of each, I would be happy to drop a couple in the mail.
Dave
9
Springfield Or
If there is a place by you that rebuilds hydraulic cylinders. They can probably match the old ones.
Daniel 4:2 I thought it good to declare the signs and wonders that the Most High God has worked for me.
Josh
12
Portland, Oregon
Josh,
"230"
2 3/4 OD
2 1/2 ID
1/8 Thick
"227"
2 3/8 OD
2 1/8 ID
1/8 Thick
Dave
Yeh I'll take a pair, let me know how much in a PM.
Josh
12
Portland, Oregon
Oh ill still drive it, ( put over 500 miles on it last week), Just prefer to not leave 1/4-1/2 a tank of a fuel on the road every fill up.
Floridianson
2,503
Interlachen Fl.
Realy there is three O ring to a head. There is the one on the fuel control leaver that should be replaced if you can find it.
davey8943
Columbus IN
Floridianson,
I changed that on mine after I swapped the Head O-rings and it was still making oil. I just ran down to the local hardware store and picked up the size that came closest to the (now flat) one that I pulled out.
Do you happen to have the dimensions? I would like to order a Viton ring, and would like to have one in my hands when I start to pull it apart.
Thanks,
Dave
