Data plate ground down on GL buy
Mike929
22
DFW, Tx
How can I get information on my USAF truck without the data plate. I have the S/N but that is it. S/N is 1040-10443. I was going to order a reproduction data plate but would like to have the correct data for the truck on it.
Also, I'm trying to fill out my SF-97 but do not know the year. I guessed it was 1986 based on the USAF "blue warranty tag". Should I just put 1986 on my SF-97 and move forward since the info has been destroyed?
papercu
31
Baxley, Ga.
If you go with 1986 your DMV may want a 17 digit VIN. I've read about people just adding zeros to make the correct amount. Good Luck, Wayne
Mike929
22
DFW, Tx
Carnac can not help the Army does not keep track of Air Force trucks.
That S/N is the VIN and 86-87 is the right year. So that is all you should need.
Thanks, just submitted the SF97 request from GL.
What other info is on the data plate where mine has been ground and painted over? I want to order a new plate and was curious if I would be able to recover any of that info through research?
Thanks,
Mike
Crawdaddy
Louisiana
My biggest question is why was the plate ground down and painted over? I can't think of off hand any reason for the military to deface just the ID part of a data plate. They've surplussed plenty of things with swapped or missing dataplates. Unfortunately I do not have any wisdom to impart.
jasonjc
289
Gravette Ar.
Its a OKC air force thing. My truck they took ALL the plates off the truck.
The builder name (AM Gen in your case) contract number. It all kinda depends on the plate. They had diferent stuff over the years. Some one on here with one of these newer trucks should be able to fill you in on the stuff you need.
Warthog
232
OKC, OK
So what was the date stamped on the warranty tag? Did your brother get a closeup of it? And did you look on the bed for the unit number?
I posted pictures of where to look in the other thread where you where asking the same question. (duplicate threads are against the rules by the way ;))
Mike929
22
DFW, Tx
So what was the date on the warranty tag? Did your brother get a closeup of it? And did you look on the bed for the unit number?
Here is the Blue Tag. Nothing for a date. I submitted the truck as a 1986 AM General Corporation this morning with the Serial number listed above.
emmado22
147
Mid Hudson Valley NY
Warthog
232
OKC, OK
. I have the S/N but that is it. S/N is 1040-10443... I guessed it was 1986 based on the USAF "blue warranty tag". Should I just put 1986 on my SF-97 and move forward since the info has been destroyed?
The pictures I posted on the other thread shows my VIN as 1040-10100 and it was delivered May of 1987. Yours was built after mine. Your truck is a more than likely a 1987 (possible an 1988 ) and not an 1986.
Contact GL now nad have them change the paper work
Mike929
22
DFW, Tx
Dang it. I knew as soon as I sent in the request, I would find out I was wrong.:(
Request sent to GL. I will have to look into the insurance Monday since all my paperwork is at work. I hope they don't jack my rates because it is now 24 years old instead of 25. :(
