- 8,539
- 2,754
- Monrovia, Ca.
Hey all,
I ran across a GPS unit this past weekend at the SCMVCC meet. Stupid me, no pic, I only got a model #.
R 2401 D/U
I didn't get an NSN
It is a bit bigger than a .50 cal can. Has a black strap, takes 3 AA batteries mounted to the battery compartment lid as well as a lithium battery in the compartment that measures apx 4"w, 2"t and 5"h and has a 4 or 5 pin twist lock connector on the battery, the battery is 2, 12vdc circuits. The GPS antenna is fastened to the top of the unit with 2 canvas, well nylon, pouches at the ends and it is pulled out of the pouches and attached to a black flexible antenna. There is a hand held keypad/display unit in another pouch on the end.
The guy had some lithium batteries on the table that he said were dead. I put one in it and it did fire up and went through it's start up sequence, then flashed a low bat and wouldn't go any farther. I searched on the net and here and came up with nada. From my poor description, can anyone help me out on an ID? I'd like to pick it up, but first want to see if a battery can be found.
R 2401 D/U
I didn't get an NSN
