Deuce won't MOVE.
m16ty
218
Dickson,TN
You'll have to pull the trans to access the clutch. I don't know how heavy the trans is but you don't want to try and pull it by hand.;)
Sounds like you don't know a lot about changing clutches. I suggest you read the TM and understand what you are doing before you start turning wenches. It's not complicated but you've got to do things a certain way or you'll never get it done.
k4vem4n
Fort Lauderdale, Fl
http://www.steelsoldiers.com/deuce/52409-how-transmission-changeout.html?highlight=changing+transmission
Try this, once you do it once, you should understand it well enough to do it without instruction. It is a rather simple job to do in my opinion, except you are dealing with a lot of weight, I believe the trans weighs close to 300lb. get a good come-a-long or chain hoist. Plus the output shaft bolts are a PITA to get to, so patience is also a necessity.
The first time I did it took about 5 or 6 hours, the last time I did it, it only took just over an hour (by myself). Practice makes perfect.
Take your time, be safe, and good luck.
ferb444
Johnstown, PA
Got the truck moved, had to tow it with a high lift. Looking under the truck the clutch feels real shakey. I push the clutch to the floor and i can shift into all 5 gears, including reverse. I'm going to read more about changing the clutch, Could it just be out of adjustment? how would you adjust the clutch? where can i get a new clutch? thanks again to everyone.
73m819
325
gainesville, ga.
YOU REALLY need to read the TMs, like before owning the truck, I guess late is better then never
Start with the -10 (operators manual) and go from there.
You can find them here
JATONKAM35s HOME ON THE WEB
S&C you beat me to it
G-Force
allendale nj
Either the clutch is shot or the bolts on the pressure plate loosened up causing the clutch to not engage. Either way, you need a clutch.
