cgtboy1988
- 0
- 0
- Tucson, AZ
I am thinking about getting a M109 deuce to use as an offroad/towing/RV/etc vehicle and need a good 12v electric supply (for things like a CB radio and inverters for various electronics). In any event, this topic has been covered to a pretty good extent with people using both battery equalizers and separate alternators. I was thinking about going with a triple alternator setup though, consisting of the stock 24v alternator for the primary driving batteries and two separate 12v alternators to power two separate battery packs. One of the 12v sources would be for things like stereo, aux lights, CB radio, etc things that would be controlled generally from the cab in addition to balancing other items with the other circuit. The other alternator would be used for things like a refrigerator, rear box/living area lighting, microwave, etc with 1500 watt pure sine wave inverters. As I would have two 12v supplies, however, I thought about having a switch to use them as a backup ignition by wiring them in series. I have attached a diagram of what I would do. Is there anything I seem to be missing in the diagram, or anything that would likely not work? I think that running the two 12v supplies in series for an extended period of time may not be wise, but it seems to me that it would work well as a backup ignition source. I would not be changing the stock 24v setup except adding a switch on the battery- I would simply be adding two other alternators.
