3rdmdqm
- 135
- 43
- Woodbine Maryland
I pulled the in tank fuel pump because it was running but not pumping. The bottom had fallen off. Repaired the bottom, pumps fine now. New problem arose. I took off the cover to the in-tank fuse to check it and found diesel fuel inside the cover. Why would diesel fuel be inside the cover? What would cause enough pressure to force diesel fuel into this cover and make it accumulate so when the cover came off it trickled out? The tank was less than half full. I see there is some type of gasket inside. Gasket had air bubbles and fuel under it when you press on the top of it. Would the fuel sloshing around in the tank migrate up through this gasket and accumulate inside the cover? Is this a simple gasket repair fix?
