forestMog
- 2
- 8
- Georgetown, Calif
Has anyone adjusted pressure on the front (belt drive) hydraulic pump? I put a gauge on one of the quick connects and measured about 1900psi where it should be over 2500psi. After a couple seconds it drops to about 1000psi.
The v-belt has the right tension.
The SEE tractor has a Unimog 406 front hydraulic system. Thanks to RockyMountainMoggers I was able to find a hydraulic system test procedure in TM 5 2420 224 34 pages 2-15 to 2-22 to try to isolate the problem. It details a test for flow to measure pump efficiency at least 75%. However, I don't have a flowmeter so I am wondering if I can substitute a tank for the reservoir and weigh it between steps to get a flow accurate enough to use in the test. The SEE hydraulic control valve appears to have an adjustment I don't find on the 406. The picture shows where the relief valve is located (see the lead seal on safety wire) but I don't see an adjustment.
From my search on the internet this does not seem to be a common problem on Unimogs. Hopefully there is someone here with deep knowledge of Unimog/SEE repair history.
Thanks to all
Paul
Thanks to all
Paul
