southdave
- 6
- 38
- ripley, oh/TDY Lordstown,Oh
oil is blow by, looks alittle excessive have tried cleaning the cdr valve ?
GearWrench 85299 5 pc. Metric S-Shape Reversible Ratcheting Wrench Set#I need a better clue than that...Where can I look online to find the right angle and bend in a wrench to get at the IP bolts on a 6.2l
Yea, thats right. The right pic is of a wrench that helps turn the pump. A long pry bar on the back side ( on injector outlets ) will also work. Be gentle, it shouldn't take too much pressure to rotate it a little it once the mounting bolts are loose.I couldn't turn my IP by hand so i made a wrench like this to help.
You can buy them but the ones i saw were crazy expensive.
But it did help, now you know you are getting fuel to the injectors and that they are good.cracked each line ... and each one made it run worse... so that didnt help. .
