- 9,576
- 211
- 63
- Dickson,TN
You may have to use a chisel to get the nut broke free. This can scar up the nut pretty bad but I've had to use a chisel before to get them broke loose.also the front drivers spindle nuts seemed to be torqued down so tight. i bent all the ears off the retaining washer up put the socket on there and tried to loosen it but nothing. all i did was accomplish to bent the socket which was made out of i believe 1/8 or 1/4 inch steel. so i sprayed it down with wd-40 and decided to let it sit for a while and then to do it again once it is all soaked in.
