ApopkaFL
Banned
- 596
- 0
- 0
- Middlesboro KY
Aa most of you are aware I am building a M35A3 into a 4 door crew cab. I need a class IV hitch in the rear. Can some of you guys lead me into the right direction for this project? (YES I use the search just did not happen for me) I am need to be able to pull a f350 8500 pounds is the reason I am needing the class IV hitch.
Hitch Classes
Hitch Class
Max TW
Max GTW
I
up to 200 lbs.
up to 2,000 lbs.
II
up to 300 lbs.
up to 3,500 lbs.
III
up to 500 lbs.
up to 5,000 lbs.
IV
up to 1,000 lbs.
up to 10,000 lbs.
I forgot to say that this truck is 11ft tall. 8 " lift with the 1600R20s so It will require a drop down hitch of some sort.
Hitch Classes
Hitch Class
Max TW
Max GTW
I
up to 200 lbs.
up to 2,000 lbs.
II
up to 300 lbs.
up to 3,500 lbs.
III
up to 500 lbs.
up to 5,000 lbs.
IV
up to 1,000 lbs.
up to 10,000 lbs.
