- 2,960
- 29
- 48
- Tiro, Ohio
Found an Oliver 2150 tractor at the fair. Has a multifuel engine without the multifuel capabilties. Different intake, exhaust, turbo, injector pump, altenator/bracket. Also, it was not a TD block. Heads, injectors, oil filters, block, and oil pan look the same. Block off plate for the air compressor bracket.
It has what looks like the military oil filter on it, I thought the tractors had spin-on filters. Water pump suction side is huge, like 3in hose and fittings.
From what I've read, the 2050's had a non turbo engine, 2150's turbo. The turbo is in a bad spot for photos. From what I could see, it did not look like any of the multifuel turbos. Also the engine's use different pistons, with a 18-1 compression.
Horsepower was 131 at the PTO for the turbo.
