deuce fuel pump
barnetc1
canton georgia
My pump quit. Have been running truck without pump for couple months. Was working good till i ran out of fuel, now can not get truck to crank. Anything im not doing that would help. I have fuel to sec. Filters but just wont run.
SCSG-G4
PSVB 3003
3,272
Lexington, South Carolina
If your in-tank pump is not working and you have 'soldier B' and an air compressor - then you can restore the prime! What you need to do is to make sure there is at least 10 gallons in the tank (more is better). Have soldier B put the end of the air hose in the open fuel cap, then try to plug the rest of the opening with a rag held down by a hand or other object to slightly pressurize the tank, then crank the engine. 10 seconds on the starter, then let it cool two minutes, repeat five times. If still no go, you may have made an IP problem by running out of fuel, and that's above my pay grade.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
OR, use a leaf blower! (or a mother in law)
Coal Cracker
Weatherly, Pa.
I agree with ODdave, the in tank pump is there for a reason, if the fuse blew, it did so for a reason., my tank pump blew the fuse then quit, after removing the pump I found it was starting to use more voltage due to age/wear. I like my injection pump so I bought a new pump Assy. 2cents I'm just applying some tough love here.
