ApopkaFL
Banned
- 596
- 0
- 0
- Middlesboro KY
Does this drive shaft look good in the postion its in?
I believe you want a min of 3 degrees working angle and no more than 7 degrees on u joints for driveshaft. there is a tool you can get for reading angles on driveshaft.Like somebody else said need angle for needle bearing to move in caps.
fwiw, never run a cardan joint without some angle on it. The needle brg's will not roll therefore will not transfer lubrication and suffer from impact loading.
Help me out here as I'm adding about 8-9" to the wheelbase of my bobber, but I can't figure out what your picture is of. Is this a really lengthened bob, an M36 or what? I won't need a two piece driveshaft for my lengthening, will I? Plans are to use a driveshaft loop just in case things go awry.....Does this drive shaft look good in the postion its in?
DOH! Is this a crewcab?Help me out here as I'm adding about 8-9" to the wheelbase of my bobber, but I can't figure out what your picture is of. Is this a really lengthened bob, an M36 or what? I won't need a two piece driveshaft for my lengthening, will I? Plans are to use a driveshaft loop just in case things go awry.....
Oh my............noShouldn't the rear u joint be turned 90 degrees from the front joint?
My bad, should have looked at bigger pictureOh my............no
