- 881
- 521
- 93
- tucson AZ
I've been driving the 1009 like there is a raw egg under the accelerator pedal....this mornings fillup computes right at 20 mpg. I'm pretty happy with that.
I've been rolling my 33x12.5R15 BFG A/T's at 36psi and, until now, hadn't thought twice about it. Looks like I'll be pumping those babies up a bitI have been getting a constant 18-19MPG with my oh-nine. Adding Diesel Kleen evey other fill up. Running 65 on the freeway, 33's at 40psi. Way better than my GTO.
I have BFG A/T's as well. L O V E them!!! Had them put on July 2010 and the TP has stayed the same over the past year. I'm also running with a K&N air filter.....Not sure if it matters though. I drive mine just about everyday!!I've been rolling my 33x12.5R15 BFG A/T's at 36psi and, until now, hadn't thought twice about it. Looks like I'll be pumping those babies up a bit
Must be doing something wrong on this end? I continue to get about 15.5 mpg no matter how I drive. Wonder if odometer is shot? I here all speaking 20+ mpg all the time. Need to go back to gps and re-evaluate. Motor seems tight. I wonder how many are realizing 15.5 ish and how many getting 20ish? Any thoughts. DMLII sends...
It looks like you have an M1009 and he has a M1028. It should be expected that they get significantly different miles per gallon. M1009 should get way, way better.dokwatson, sounds like you and i are realizing similar mpg under same conditions. ip condition has been brought up. hows condition of yours?
