Dabba
- 0
- 16
- Long Island, New York
Hello, quick question. (And ive searched) My gen 2 light is coming on and off intermittenly, sometimes staying on if i have the truck parked, though can rev the motor and itll turn back off. Sometimes the voltmeter will actually show in increase in the volts then what its suppose to be when it begins flashing. Looking at other threads.. i take it the regulator is going bad?
Other things ive noticed that may or may not be related... The rear battery... the postive terminal area is corroding a bit with white stuff around the contacts (going to clean that today) I actually had the truck not give me any power when i went to start it one time, messed with that wire and it was fine, so that needs a cleaning..
The other thing is, behind the air filter on the firewalls, theres a plate. And from behind that plate ive noticed a black wire poking out with a ring contact on the end of it, like its supposed to be bolted down... But, its just loose, and looks like its never been connected. I didnt want to screw with it, because i have no idea what it is. Id like to show you guys a picture but.. its not available at the moment. I can only guess it was hidden behind this plate the entire time and then came loose. Any ideas? Thanks guys
