Going to try to fire up the electrical system in the shelters I got for our Co Communications board this weekend. These are actually print shop shelters (darkroom/typeset in one unit and print press/paper cutter in the 2nd shelter).
To the right/curb side of the door on exterior is a milspec electrical connection. 4 terminal. Inside is a 125amp breaker panel 60hz. Looks like all equipment is (including the Heat/AC units) is single phase 60hz. The genset pigtails are also 4 strand - wires are marked ground, L0, L1, L2.
I can use a MEP003 (terminals are marked same as the wire pigtail). Or I can use a MEP004 (termials are marked L0, L1, L2, L3). I'd prefer to use the MEP004 as easier to access/hitch up.
Question: Are shelters wired for 3ph supply and crossconnect inside the shelter breaker panel to balance the load? Or are they wired single phase? What standard supply voltage?
How hook up the pigtail for correct supply to the shelter for MEP004? What setting on the genset control panel and connection board?
Or is the entire thing 1ph (should use the MEP003?
