Question about adding an electric fuel pump
superburban
SL,UT
Just a word of caution if you install an electric fuel pump in front of the mechanical one: If the diaphram on the mech. pump breaks, the electric pump will continue to pump and fill up the crankcase with deisel. Just be aware of that possibility.
I install electric pumps in all of my 6.2's and 6.5's, though. I usually leave the mechanical pump in place, but loop the supply and pressure fittings together, so that they stay clean inside. That way, if the electric pump ever gave me trouble, I can just "rearrange some hoses" and get back on the road.
tequilaiam
Brazil, IN
Can I ask where you connect the supply hose to bypass?
A)At the threaded fitting comming out of the pump
B) at the input nipple of the filter
C) Other
