srodocker
- 69
- 48
- Lacey, Washington
hahahahaha
Nah Zy follows his ss handle. Hes a good guy.If you promise no rape or theft I have some floor you could occupy for the night. I'm about 10 minutes away from the Wal*Mart.
O wow!! that sounds allot more intimidating than i had hopped.rolling18,
I've done a clutch. Things to remember. The sprague shaft need to be retracted for transmission removal and installation. The flywheel bolt holes are NOT symmetrical, it will fit only one way. You should have a clutch alignment tool or putting the transmission back sucks. If you can clean your transmission before starting, you will get less dirt in your eyes. You will need something to clean the flywheel/clutch. Using a transmission mount from below may be easier than a chain hoist in the cab, if your floor is smooth. Remove the bench seat and floor panels first, then use the hoist from the driver side so you can move in the cab easier. Hope that helps.
If Scott doesn't I need one.Hey Scott, do you want some convoy signs for the run to Brads? I just got a bunch!
appreciate the offer but ill be coming in late and will just crash in the truck, I don't deny theft, after all I have the green affliction.If you promise no rape or theft I have some floor you could occupy for the night. I'm about 10 minutes away from the Wal*Mart.
It looks like we are going to make it unless it pouring down rain. We are bringing the HEMTT as anything else would have to come by trailer and what fun would that be?will there be many people bringing their MV's???
anyone done a clutch? I need to pick your brain.. heh
UPDATE.Right now, the ATV is on hold until some title issues are settled up. Things kinda worthless to me if I can't title it in Washington and apparently in Oregon that isn't a big deal....
