single tires to duals
m35a2cowner
Columbus, Ohio
On a related note, I have done some initial search of the site and been unable to locate information concerning rims that would allow me to keep the dual wheel configuration (deuce) , up-size to 1100X20s and allow me to spend next to nothing for the whole thing. I know that is a tall order but, nothing ventured, nothing gained. Thanks for any help you can give me. :razz:
91W350
57
Salina, Kansas
Just some labor and the cost of tires and tubes, the deuce wheels will be perfect. You just gain 4 inches in diameter and the fuels will be a little closer together.
Ridgerunner
Holland, Mi
Duals Rule.........
To me, a singeled out Deuce with 9.00x20's or even the 11.00x20's looks like it has Polio, with it's little cripple legs back there.
If I ever ditch the Bobbed Deuce and run a regular normal Deuce, it will be dualled, for sure.
Torisco
50
Bishop, California
1100 X 20 NDT Duals on a Deuce are my cup of tea.....
And I have seen some mighty nice singled out wheels as well.
Love the variety of life.
DEUCE1209
Western MA
Thank you all very much for the great info! this was exactly what i was looking for. Now i understand how the duals fit together.
** plym49, Have a safe trip to VT. I'm only about 30 - 45 mins from 91 so if you run into any problems going through MA, let me know and I'll come help you.
m35a2cowner
Columbus, Ohio
Duals
I know, its just that I would like to get away from the split rims and go tubeless. I know its a modification, but I could do the tire work at home and not have the cost of tubes and the need to take them somewhere for repair.
plym49
171
TX USA
Sounds good, PM sent.
91W350
57
Salina, Kansas
They are not really a true split rim, they have a lock ring. You can still do them at home, it is a lot of work though. Glen
m35a2cowner
Columbus, Ohio
After all the horror stories of the lock ring coming off I just don't want to fool with that either. Also, if I have have to buy tires then I don't have to fool around with or buy new tubes and boots. Just looking for the simplicity of tubeless while keeping the duals.
ODdave
41
lansing michigan
Not shure what kind of tubeless rims your going to run that your going to "swap out " tires at home...... If your going to run duals you will be limited to Drop Center rims. Good luck changing those any easier than snap rings.......
P.S., those "horror stories" come from idiots not knowing how to properly clean rims and mount the tires. Darwinism is a bitc*
m35a2cowner
Columbus, Ohio
rims
Back in the Dark Ages I use to work for U-Haul. Saw the tire guy change many a tubeless dual tire/wheel in the parking lot with a tire hammer and tire iron. That's the type of set up I would like to have.
Katahdin
24
Scarborough, ME
On the flat tire issue, I would much rather run one flat and destroy the tire than take a chance in traffic changing one. Along the same lines, I would rather recognize right away that it is flat and look for a solution, than catch one on fire not realizing it was flat. Once you get a tire and undercoating on fire, it is next to impossible to put out. Besides, it must be just my luck, but front tire flats are much more prevalent than rear tire flats for me. Everybody has their own idea of what works good for them, it would not be much fun if we were all the same in preferences and tastes. Glen
Good point, I once had a tire disintegrate on a dually Ryder moving truck on the New Jersey Turnpike on a Sunday. My only saving grace was being able to limp down to the next exit because Ryder's roadside assistance wasn't authorized to work on the NJ turnpike and good luck getting help on a Sunday.
ODdave
41
lansing michigan
Try that with a 20 or 22.5 with the "thick" sidewall the mil tires have. Might change your mind.
91W350
57
Salina, Kansas
Watching this might change your mind too. That is a lot of energy!
[media]http://www.youtube.com/watch?v=8W_a90uARa0&feature=player_embedded[/media]
91W350
57
Salina, Kansas
I may be in for the Darwin award, I always ran a pair of 3/8 chain around the tire and wheel through the holes and used a remote air line. That would be using the four hooks in a cross pattern to secure the ring in the case I assembled it wrong or did not have the ring seated properly. Now I wonder if the four loops of chain would hold or if I just added projectiles. I use a clamp on air chuck and stand back a few feet. I never had one that was not seated, thankfully! Glen
91W350
57
Salina, Kansas
Another one! These guys are living on borrowed time! Glen
[media]http://www.youtube.com/watch?v=VRjoyCLPk7I&feature=related[/media]
Prankster
Ponca City, Oklahoma
Wow!
I see that he had a safety chain locked around the wheel, and tire.
My Grandpa said: Always put a board across the entire wheel, and stand on top of it when you air up one of those big tires.
91W350
57
Salina, Kansas
I think you find a cage or suitable substitute, use a clamp on air chuck, and stay as far away as you can, preferably behind a solid object while it seats. I do not think a board is going to reduce your injuries by much. I do not want to be on top of the wheel or ring at all when airing them up. 2cents Glen
