Pulling 2x2s out of stake pockets
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
As I said before WD40, C clamp, a couple small blocks of wood (to protect the wood) and a rubber mallet.
About 5 minutes and it is out.
This will only work if they aren't broken off already (which I think his are).
abh3
Florala, Al
Using BBQ tongs, gently place a burning charcoal briquette atop each broken 2x2, retire to the above mentioned lawnchair and 12-pack to monitor progress...
treeguy
Fort One Bay - Cape Cod, MA
What is the opinion of heating the metal around the wooden problem until the wood starts to char which may shrink it a little? The charring might also lubricate the pocket on its way out like graphite does for certain applications. Though I do realize that this trick may/will make a mess of your paint if you apply too much heat.
AW HECK.......soak the wood with gas and lighter' up!
If none of this works I think a video camera and some C4 would create some smiles accross the board! :beer:
hndrsonj
363
Cheyenne, WY
Why even risk harming the bed when you can get them out in 10 minutes with a drill??
hndrsonj
363
Cheyenne, WY
The problem with posts like this is that someone with no mechanical ability that reads this stuff will try to "heat" the bed to remove the upright like you all said to do. Please when you give advise, give good tips or don't at all!aua
rossM4
boonville IN
drill and big screw driver is about the only way to not damage the rig. If you get real mad at it then im on board with the guys talkin camera and explosives!!!!!!!! (dont forget the 12 pack and lawn chair):beer:
DUG
73
Mesquite, NV
I had to do this with 3 stakes. With a 3/8 inch 12" long bit it took probably 35 minutes total. It's very simple and only takes about 10 minutes a hole.
Ten minutes per hole times three holes equals 30 minutes. What were you doing with that extra five minutes? Sounds like you wasted time you could have used to do some more PMS.
:mrgreen:
hndrsonj
363
Cheyenne, WY
:mrgreen:
Chester got out, I had to chase him down.:-D
