Multifuel turbo on 6.2 Deisel
Gunfreak25
620
Yuma, AZ
I was wondering if the Multifuel turbo could be used on a Military 6.2? Why would and why wouldn't it work? It would sure sound sweeet.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I doubt it would work as the manifold design is WAY different. You'd be better off using a 6.5 setup.
eagle4g63
34
North/west Indiana
Anything is possible, just have to get creative, make room or new header.
That is how I put a turbo that is bigger than the multi's turbo down in my car with a little 2.0l motor....everyone said it wouldn't go but move a few things get a set of headers made and bam..I have a turbo putting out so much boost it's almost scary!!
eagle4g63
34
North/west Indiana
However, I forgot to add. The 6.2 may or may not move enough air for you to get that high pitch whistle out of it, if that is what you are after, just have to try or if someone has done it already they would know.
Dave Kay
29
Kingman AZ
Boy, when it isn't otherwise OBVIOUS--- I really HATE to show my ignorance--- but if you go turbo on 6.2 does that eliminate the IP? From what I've heard the IP is the weak link in using WMO/WVO set up and therefore is not practical...2cents
Farmun
Ashland City, TN
I think the IP is still needed, whether a turbo is present or not. Or is IP something other than injector pump?
-jeff
4x4e350
Vestaburg, Mi.
I turbocharged a Ford straight six 300 with a Turbo out of a Nissan 300 ZX. The thing with turbos is the amount of air they move through the engine. My 300 will start starving for air around 2800 RPM, but I get absolutely no turbo lag right off idle, the turbo starts producing power right away. Which is right on the power band of a straight six.
You need to figure the amount of air the old multi fuel required, at a certain rpm, and figure how this will work with your 6.2.
Gunfreak25
620
Yuma, AZ
I cannot afford either a 6.2 or a 6.5 turbo. I've seen the Multifuel turbo kits sell for under $250, and of course making custom intake's and pipes is always easy using PVC and rubber boots to connect pipes. After looking up the numbers, I don't think it would work. The Multifuel will use about 1160CFM at redline and just over 330CFM at idle. The 6.2 will use less than 80 CFM at idle and just under 300 CFM at 3000rpm. Those numbers seem low to me. But I don't think it would be able to spin the turbine fast enough to really get anything out of it, as said above.
usmc320
RVA
I might try that with my lawn mower too. :twisted:
