chicagodiesel
- 1
- 0
- Chicago, IL
Can't say what's normal, but mine does too. I'm out of town this weekend but we should meet up and I can help you change the balancer as I've been through that one already and it's just labor intensive (fan, fan shroud, all belts, crank pulley, etc...). I pulled all my injectors and cleaned them plus advanced the timing by about a quarter inch and the vibrating is still there but way way less prevalent. I'm going to be changing the water pump in the next few weeks and will change the timing chain at that time...so maybe that will help out with having the pump so advanced. Either way, works in progress. Good luck and see you on the road sometime.
