DrJekl
- 1
- 18
- Clarksville, TN
No offense intended here but I think you should keep an eye on your mechanic. If he says your differential is bad, I'd get a second opinion. Sounds to me like you have an original rear set up in your truck, he is playing on the brand name Detroit Locker with a generic term posi-trac (which is actually a brand name used for a limited slip dif but I am not sure who owns the name) and is comparing it to a Gov Loc. He has likely only seen the Gov Loc in civilian vehicles and is using that for reference. GLs are normally open and lock up when a wheel spins. a DL is normally locked and unlocks (the chirp you hear is caused as you turn corners and it is still locked) when you turn corners and other times one wheel spins faster than the other.
