- 2,419
- Columbus, Georgia
You Sir do excellent work. Plus...you take good pics.
Thank you for sharing your work!
The addition seems to be what you wanted on it and that is the way it should be.
Thanks for keeping the progress coming on the pictures.
If you see a 43 running around it is probably mine that got obsoundered with here about a month ago - it was blind thievery. Can you believe the culprits loaded it up in broad daylight and took it. Had to have had help - its more than a one man job - probably a whole gang of culprits.
What you going to go after next on it ?
In all the research I did (for the U.S. Army only), and in the answers to my questions on SS regarding the paint color for the rear of the ambulance, I arrived at the following;Did the rear interior come painted white from the factory or was it done by the military? My white was pealing like a old house. There was a base layer of OD. The paint was almost non existent in the bottoms of the storage bins.
I have attached some info on the Sea Foam GreenNil Spec. color.Thanks, the way the paint was pealing I didn't think it was factory applied. I haven't seen one in sea foam yet, it could be a good choice.
Torisco - do not take this the wrong way - its not meant to be harmfull.
When I got the 109 - sea foam was in the interior and I could not get rid of it fast enough. It gave me the creeps and made me wanna puke everytime I looked at it.
When I sandblasted the back of the 43 I saw no removing evidence there had been seafoam in it under the layers. If I were a momentary patient in the back of one and it was painted sea foam - I truely believe I would have to slit my throat as it would make me nausiated.
I am color blind - but I can sure as heck figure out this color for some reason.
I see absolutely no reason NOT to paint the rear if that is what you want and more power to you - go for it. The white that was designated for the square on the red cross that coordinated with the od and also the specific red. I just decided to use the same white on the interior - just looks more hospital like.
