Tell me about it! My truck isn't any taller than a lot of new Dodges or Fords! Just goes to show, if it looks like you're having too much fun, they'll pass a law banning it. Where in MN are you? I don't think I've seen any other lifted CUCv's around here. We're trying to get a bunch of members from around here together some time in the spring.Nice truck! sucks you got cought on the lift law. i run a 4" lift and 37's as well. Funny part about the lift law here in MN is that there are trucks that roll off the lot and dont meet it.
it's green inside dangit!!!how can you have od fever when the truck is white ?
It's green UNDER the white!!! Haven't you ever heard "it's what's inside that counts?". I'm protecting that precious CARC with a light over-coat.its still not Od green.
Thanks! Not sure what you're referring to here. Correct what? I will say that the shackle flip pivots the rear axle backwards a bit, that helps to correct the driveshaft angle, but it also meant that we had to repeatedly heat and bend the passenger side shock mount on the axle to keep the bottom of the shock from hitting the axle under full articulation. I also have not extended the bump-stops yet, which I probably should soon before I break something.Truck looks great! I was thinking about getting the same kit for my truck. Did u have to shim the rear or does the shackle flip correct it?
There was quite a bit of contact with the outer fender, which I trimmed to correct. I just used a grinder, scribed a straight line and cut with a grinder, then used hammers to roll the edge over and coated with primer, chip guard, then paint.Looks like there's a little tire contact with the fenders up front?
I only ask because I'm building a truck JUST like this.
Oh yeah, long time ago. I've done a lot of "little" things to the truck since I've had it that I've never reported here. Might as well now:do the DH mod yet?
