Both ends of the wire in a Douglas connector are male. There is a female sleeve that connects them. The outer steel shell either has "pins" or a slot for the pins. As I recall, the pin / slot orientation can be used to polarize a connection if there is an in-out difference. A tail light will have all the connectors identical orientation, while other equipment with one lead connected to hot and one lead connected to ground will have different polarization - unfortunately, I can't recall which is which. The Douglas connectors are getting harder to find, and the correct MIL crimper is available, but expensive. The cheap crimper that came with the Douglas service kit is a hunk of junk - most are worn out long before they show up as surplus. Buchannan makes an electrical crimper for a sleeve-type connector that can be used on home wirting that works pretty well, and its usually cheaper than the used Douglas crimpers.
