joshuaz223
- 2
- 0
- Central Square, N.Y.
I was moving coal for my brother yesterday a short distance on private roads so i thought i would do a little test to see where the limits are for my truck. I have stock deuce front springs on the back and 395 tires on stock rims. my truck is not shortened. all the wheel cylinders, the master cylinder and the air pak have been rebuilt. i run my tires at 38 psi empty rear and 45 front. that seems to be the best with my tires.
6000# tires start to bulge. brakes work well handles normally.
8000# tires bulge enough you would want to put in air if you are going very far. brakes still work well enough to slide a pallet of coal 3000# if you want to. starts to feel top heavy in turns(tall pallets)
10,000# tires have to have air. went up to 50psi to get normal bulge. brakes are effective but not great. springs are touching rubber snubbers but not crushing them. very top heavy in corners and tires roll on narrow rims.
12,000# tires have to have 65psi air (max is 95). brakes are unsafe for street use. spring are crushing snubbers but not completely. corners are scary tires rub box in turns and bumps. tire roll on rims in turns is bad.
I never used low range and the truck would always reach 55.
