- 2,162
- 66
- 48
- Zimmerman MN
What kind of $$$ do these normally go for? I'm guessing half a million in great condition?
Wold be interested in hearing what people were offering as tradeps, Its been Going CRAZY on EBAY. Got offered some very cool trades from people! But looking for cash and carry people.
I offered two deuces but no go.Wold be interested in hearing what people were offering as trade
The varying prices with FLYABLE helicopters is the time remaining on components. Nearly EVERYTHING is time limited and has to be either rebuilt or replaced. I've seen helicopters that were extremely cheap, but under further inspection nearly every component was timed out.What kind of $$$ do these normally go for? I'm guessing half a million in great condition?
You have to buy a wreck to get the data plate and logs for the airframe and then you can "rebuild it with other parts". The components have no serial numbers so you are SOL there. You could try and use the component numbers off of a salvage part but I would not do that. You could probably find a good transmission housing and have the parts from the no serial number used to rebuild it. Same problem with the engine; nothing cheap when it comes to turbines. Blades will just have to be replaced with servicable units.The varying prices with FLYABLE helicopters is the time remaining on components. Nearly EVERYTHING is time limited and has to be either rebuilt or replaced. I've seen helicopters that were extremely cheap, but under further inspection nearly every component was timed out.
Since there are no logs, data plates and missing serial numbers, I'm not even sure a "restricted" catagory applies but it isn't a candadate for a Standard Airworthiness Certificate, that much is certain. I'm not up on what it takes to make it airworthy for restricted, it's been too many years since Embry-Riddle and possible changes in the rules.
When I could afford a "restricted" one with some good component times left, the wife said no. Now that she likes them, the banks account says "no".
Pretty toy in any case!
