acesneights1
- 23
- 20
- CT
When I am using alot of accesories particularly the snowplow something starts clicking under the dash somewhere and the volt meter drops but I can't figure out what ? The more things I have on the more it does it. ONe of the fusible links going to the lug on the firewall was burned up. I fixed that but no change. I'd post p;ics but limited access as things are p;ost apocalyptic here. No power, communication nothing since saturday. I gotta figure this out. it seems if I got the heeadlights on, the heater going and then use the plow it gets worse. All the wiring for the plow including the power for the control are run directly off the front battery, not the fuse block. What gives ??
I did the doghead relay mod and this is happening while the truck is running.
