AndyJ
- 0
- 0
- North,Texas
I have been working on a low hour MEP 002A trying to get the various small problems resolved. The latest thing to pop up is a seeming problem with the fuel level float switch.
Whenever the master switch is placed in the RUN/AUX position, the breaker on the panel pops. I replaced the float switch and it ran about 2 hrs and is now doing the same thing.
All the fuel pumps seem to run as normal.
Disconnecting the AUX fuel pump with the float switch connected gives the same results- the breaker pops.
I can disconnect the fuel level float switch and the unit runs like a champ with no other problems.
Any insight into what is going on would be appreciated.
