STSCSS
- 36
- 0
- Rochester/MN
Hey folks,
Getting Mater up and running and have realized that there is no list that I can find of M37 parts through commercial sources’. I just found a complete head gasket set new at rock auto parts (FEL-PRO Part # HS7564C HEAD SETS (HS) are used for upper engine repair only, typically on a valve grind) For $33.79 and Autolite 2243 plugs for $6.43 each.
As you can see I pulled the header off and saw that between 3&4 and 5&6 Cyl there is considerable burn through no wonder the old truck won't start! Compression was in order #60,#90,#30,#30,#30,#10.
Now I don’t know how would be the best to produce a list but if you have a good part number that you have used in 2011 please post here I will try to make a list.
Besides Plugs, Gaskets, and Oil Filter what other commercial parts have you all found?
