unispeed
- 2
- 8
- Akron Ohio
I noticed alot of members are down on the 3116 and one main reason is that they are not sleevable?
Since I think I might be headed for a overhaul i found this and thought I would post for some carification
Caterpillar 3116 Engine Rebuild Kit (IPD One Piece Piston)
is Engine Kit contains one piece aluminum pistons. Oversize pistons are not available for this application. Please refer to Caterpillar Service Bulletin SEBF8261 for the recommended procedures on installing cylinder salvage sleeves. The part number for the salvage repair sleeve is 7C6208.
This Engine Kit contains one piece aluminum pistons. Oversize pistons are not available for this application. Please refer to Caterpillar Service Bulletin SEBF8261 for the recommended procedures on installing cylinder salvage sleeves. The part number for the salvage repair sleeve is 7C6208.
http://www.mellingcylindersleeves.c...cleId/113/New-Sleeve-for-CAT-3116-Engine.aspx
