Part # for transfer case rear seal? M1009
jdeoliveira74
wilmington nc
Ok looked thru tm's and I cannot find the part # for the rear seal in the transfer case. Mine is leaking pretty bad and I need to replace it !
thanks
Jon
doghead
4 Star General /Moderator
1,175
1984 Blazer, thats all you need to tell them.
doghead
1,175
You need to look at TM9-2320-289-34P
doghead
1,175
I think this is what you need, but I would look at the pic in the TM to be sure.
29940-0445 Seal
Warthog
231
OKC, OK
29940-0445 Seal
I think he is talking about seal #2 from the diagrams. For the rear extension
# 9449-K NSN 5330-01-096-6775
According to www.wbparts.com it crosses with the following depending on the manufacturer
13942
18992
523848
8625893
8655031
9449-K
9449SKR
NAPA shows the seal as:
NOS 18992 - Transfercase Rear Output Seal
Oreilly's has one - Part #9449
You may also need a speedi-sleeve if the driveshaft is worn too much.
