- 806
- 200
- 43
Does This Exist? Trying to Find Diesel Fuel Transfer/Lift Pump & a Portable Generator
Hi All!
I've been looking on GL a while for a Diesel Fuel Transfer/Lift Pump and a portable generator. But they don't ever seem to list to much info about these items in the description. I have tried to take models and Google them, but mostly I just come up with is NSN#, and not much else. I'm not limited to buying from GL, I would buy them from anywhere if it was the right type and good quality machine.
On the Diesel Transfer/Lift Pump, I don't want a massive pump (like one that needs its own trailer...) I was hoping to find something on the smaller size, and I was hoping to find one that was 24v. Might be to much to ask for... But the real kicker is I need a self priming pump that can Lift (suction lift?) Diesel fuel up 15-30ft from underground storage tanks. Does something like this exist in either GL or Civ Retail? The most I have really seen is 15ft I think. Don't need anything fancy, just something that works. I want this so if there is a power failure, which happens often here in the winter especially, or if there is a longer term power disruption because of some event. I can disconnect the Electric Pump and use this D/C pump to bring up fuel for the trucks and other equipment.
On the generator, Again nothing fancy. Just a 110 volt portable generator but I need one that runs on Diesel. Again GL has listed diesel generators, but usually they don't say much else about them, and most of them seem to be large in size. I can buy Civ Retail, however after researching several different companies and brands, there seems to be a pattern of negative to very negative reviews on diesel generators. So I'm not sure which brand or such I should be looking into.
Any Ideas? Does anyone use a Diesel Lift Pump or Generator like the ones above? What do you suggest?
Any Suggestions or info would be much appreciated!
Thanks!
Hi All!
Thanks!
