KsM715
- 142
- 63
- St George Ks
There has been alot of controversy this past year about whether the M101 series of trailers is designed to dump or not. (GL is not helping out with advertising these as dump trailers). Can you dump with these trailers? Yes. Will they eventually break from to much dumping? Yes. ( http://www.steelsoldiers.com/847746-post16.html )
I've never seen any pictures online of what the hinge feature on the M101 was dsigned for. In one of the threads one of our SS members found a drawing of loading M101 trailers on rail cars. That drawing showes you can get the trailers loaded with 7'1" axle to axle spacing. With an a1 or a3 that would be possible. With an A2 I dont believe that is possible because the surge brake assy. stands about 16"-17" more or less to the top and the axle clearance is only about 14"
I was bored today and the brakes needed to be bled on my trailer anyway so I decided to undo the brake line and take out the bolts just to see what it looks like and see how difficult it is. It's not hard at all. You need a 3/8"s and 7/16" flare wrenches for the brake line, two (2) 15/16" wrenches/sockets for the bolts/nuts under the box near the front of the springs and some 3/4" wrenches to loosen the bolts (hinge point) at the front of the box. You will also need to take the wiring harness loose under the front od the bed so it does not get stretched and damaged.
Is this helpfull to anyone here? Probably not, unless your trying to load 2 or more M101's on a short car hauler type trailer and keep your overall height down. Even then these trailers are light enough to just raise the tongue and stack one trailer over the other.
