top_prop
- 8
- 18
- Suffolk, VA
Then:
6. Removed the air cleaner and placed a shop towel over the intake as a precaution
7. Removed the Top bolt holding the resister to the fire wall, then the two bottom bolts
note: you do not want to remove the 4 bolts on the front of the resister pack as they hold the resister to the metal mounting plate.
8. Removed the lead that ran from the 24v bus to the resister pack as it had the fusible link on it.
