Polycop
- 1
- 0
- Nothern Indiana
The other day I was changing the oil / filter on the MEP 003a using a ch6pl filter. It fit correctly and it came with a number of big gaskets, one fit perfect and two small washer / seals. I didn't have the TM with me so I figured the fatter rubber washer went down by the spring and the thin fiber washer sealed the filter to the base of the adapter plate. In looking at the TM I think I got the fat washer correct but the thin one is supposed to go outside between the canister and the bolt.
It's not leaking now, should I go ahead and take it back apart to move the little fiber washer to where it belongs or will everything be OK till next years oil change?
