merlot566jka
- 0
- 16
- ID or TX or OK
So I need to do my headgaskets pretty quick. I am using the truck as a daily. So hoping to get it done in a day or weekend. There is hefty amounts of oil coming out of the front and rear of both heads.
So here are a few questions:
Can I leave both the intake and exhaust attached and lift both heads as a unit?
Can I re-install it the same way?
If do it this way, do I need to buy any other gaskets, other than the head gaskets of course?
Do the injectors have to be pulled out? If so, isnt there copper crush washers to replace?
So far, the plan is this:
Pull the heads as a unit, remove old gaskets, clean block and head with brake cleaner and scrapper. Install new gaskets, lower heads back on, retorque, re-connect and fill up fluids. Start and drive.
I was going to use "the right stuff" by mr. gasket for the valve covers.
I need to find the TM for setting the lash if its any different than any other engine.
Can I do it in a day or two? do I need any extra parts?
I know about the special wrench. I can weld, Ill make my own.
I know about the new style head gaskets, and will email M35Tom for the head gaskets.
Ive read about the freeze plugs.
I do not plan to resurface the heads.
I do not want to have to remove anything more than I absolutely need.
I would like to complete this with out any significant down time (corvette is down for the winter... and I dont have any other transportation at the moment)
Thanks for any advice, tips or pointers!
